control of 2 motors
control of 2 motors
I have a unique problem that i haven't ever come across before, maybe someone has thought of this allready:
I have 2 motors that are driving linear actuators. These linear actuators are positioned in such a way that they are back to back, one actuactor acting 180 degrees in the opposite direction of the other. Both motors are attached in the middle, so the linear actuators push out in either direction away from the motors.
So here is the problem: The motors that drive the actuators do not have the exact same impedance, so they run slightly differently. these actuators are placed perpendicular to the ground, and there is a load on them. When we try to extend both at the same rate, the bottom motor doesnt act at all, while the top one does. We would like to make sure that both actuators extend at the same rate no matter what the load on them. Does anyone know something that i could build/buy to accomplish this?
thanks very much!
-Aaron
thanks very much!
-Aaron
RE: control of 2 motors
Keith Cress
Gunnar Englund
www.gke.org
