Aluminum 355-T6 Castings Welding Repair
I'm new here so here goes...
This is more of a general question regarding weld repair of 355-T6 aluminum castings. Here is a little background; the castings are heat treated to obtain maximum mechanical properties, they are then repaired by welding in order to fill holes and/or correct other damage. The welded area has lower mechanical properties than the surrounding material and this may cause a strength issue. What is the proper technique for getting the entire casting (including the welded area) back to the T6 temper? Can we re-heat treat the entire casting again (solution treating, quench, heat treating) without rendering it useless? Is there a danger of causing excessive grain growth by subjecting the casting material to a second heat treat cycle?
RE: Aluminum 355-T6 Castings Welding Repair
