Thermostats low temperature range
I am looking for industrial thermostat to be able to sense ambient air temperature less than 20Deg. F (accuracy is not important) with dry NO or NC contacts. There is no problem to find 30Deg. F. Any suggestions here without using 4-20ma or external power?
RE: Thermostats low temperature range
htt
Series 54, model E54-D21BC(9333) has a 6'copper capillary bulb with a setpoint range down to 0°F at $145; or hte C54 with a brass immersion stem @ $95.
http://www.lesman.com/downloads/s14_switches.pdf (bottom of page 19 of 22)
