Seeking C.T. saturation curves
I'm seeking saturation curves for some Westinghouse ct's. I haven't had any success searching the web and am hopeful someone out there could provide me some direction. BYM L spec 960742, curve sheet 697891. The other two, L spec 834355 and 885800 are the only data I could retrieve from the transformer N/P. Any assistance is appreciated. Thanks!
RE: Seeking C.T. saturation curves
Sometimes I only open my mouth to swap feet...
http:/
I see BYZ CTs but not BYM's. Beats me.
I may be able to guide you if you can provide the Westinghouse part number that is on the nameplate.
BTW, I am relatively confident this is not the same as a BYZ, which is for zero-sequence applications. The BYM were typically cast coils in large AL or Cu housings for use on generator terminals.
