BOM combination of part numbers
Hello all.
Hope you all are well today.
I have threee belts with different P/N's (examples below)and these belts are the exact same size. However, now they want the 3 belts combined to 1 P/N.
Below is the example::
The P/N assigned I need assigned for the final belt is 11111111 from the vendor.
Ok..I have  (3) belts - 02xxxxxx_Master, 02xxxxxx_Master1, 02xxxxxx_Master2.  Again, the only difference in these (3) parts is the installed shape.  What I need the BOM to do is combine the (3) unique part numbers together, so the single line item will read the P/N 11111111 and a quantity of 3.
I've tried some stuff - unsuccessful.
Does anyone have any ideas?
Thanks!
Rip
SolidWorks 23007 Office Pro.SP 4.0
Compaq Presido 6000
Win XP
RE: BOM combination of part numbers
Sounds like you need multiple configurations of part #11111111 - each configuration corresponding to a shape found in 02XXXXXMaster, 02XXXXXMaster2, etc.
dgo,
Yes, that sounds like what I need.
Do you know of a way to do this?
Thanks!!
Rip
Compaq Presido 6000
Win XP
Rip
Compaq Presido 6000
Win XP
When you create a new configuration, there is a Bill of Materials Options where you can select from a drop down menu. Choose 'Configuration Name', and make sure to name your configuration appropriately.
Where you already have the parts modeled, you could always use Insert->Part rather than recreating all three iterations. It might make things easier for you.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Oh, don't forget to suppress the iterations you don't need per configuration.
Jeff Mirisola, CSWP
CAD Administrator
Hi JMirisola!!
Thanks a bunch for your help!!
Thanks to you dgo as well.
Jeff - - just subscribed to your blog.
Rip
Compaq Presido 6000
Win XP
No problem, Rip. Thanks for subscribing as well!
Jeff Mirisola, CSWP
CAD Administrator
Yer blogs a pleasure reading, Jeff.
Just remember to say something nice about me in the next issue!!
Rip
Compaq Presido 6000
Win XP
