laser cutting titanium with a trumpf 3kw 2530
Hello all, Im trying to cut some titanium with our laser and i'm having some moderate sucess. I just cant get a clean edge. Would you recommend using a SS tech table or an aluminum one?? Also im cutting with nitrogen.
RE: laser cutting titanium with a trumpf 3kw 2530
Typically, if you want a nice polished edge (like the one you get with Stainless cut with Nitrogen) in titanium, you want to use argon. It is more expensive, but the results are excellent.
You can probably play with the speed but the end result is going to be about the same.
Good Luck
Can we bend a titatium sheet metal
This will be a challenge in itself since titanium has a lot of springback.
Good Luck
