modeling pvc pipes in gravel swale
i currently have a gravel swale in one of the subcatchments
i want to embed pvc pipes in the swale for storage
how to i do this? do i model them as ponds?
RE: modeling pvc pipes in gravel swale
its not a pvc, its a series of hdpe pipes
Pipes are embeded exactly the same as chambers.
continuous x-section area with both top and bottom sloped @ 7%, side slope = 0
do I need to fill ou the incremental storage and cum storage?
is there any way you could kind of walk me through it if you have a few minutes of spare time?
could you kind of walk me through an example
say I have a 12" pipe imbedded in a 2'x2' stone, both sloping @ 10% for 10'
start
top stone: 2.5'
top pipe: 2'
inv pipe:1.5'
bot stone:1'
end
top stone:1.5'
top pipe:1'
inv pipe:.5'
bot stone:0'
if anyone can help it would be greatly appreciated
thanks in advance
thanks
im stuck again
the program keeps saying my pipes are above the imbedded storage
arrrrgh
Remember the invert elevation for any storage volume is always the lowest point, which corresponds to the "outlet" of a pipe. Perhaps you've entered the upper (inlet) elevation instead?
after traying over and over I realized that I was modeling from the invert in down stream when i should have been modeling from the downstream invert
