thermocouple & thermowell configurations
Can someone provide some examples of reliable and accurate thermocouple and thermowell configurations applied to piping? I am most interested in the mechanical layout and sizing as opposed to the interaction of the sensor and electronics.
I am aiming to minimize heat leak to the process fluid (LNG in this case) and to decrease thermal resistance between the sensor and process fluid. One requirement that makes this difficult is the need for serviceable sensors. Currently T-type 1/4" DIA insertion probes are being used in thermowells similar to those on the site listed below.
http://www.omega.com/pptst/SERIES_260W.html
http://www.omega.com/pptst/NB1-ICIN_INDUST_TC.html
In the extreme case of improved performance, a bare sensor could be put in the process stream, but that would be very risky. (reliability, serviceability, damage to downstream equip if it fails, etc.)
RE: thermocouple & thermowell configurations
You can make a thermowell that has a high TC material as the plug (tip) (Cu or brass) and lower TC material for the body (SS).
You can also use a bare element thermocouple in it. I have even used ones that were spring loaded to maintain contact. Use as thin of wire as practical.
You can take it one more step and put a small amount of Mg oxide slurry in the bottom of the thermowell. This will further improve response.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
