guy cable grip/puller
I have a 1" diam. bridge strand that is being used as a guy cable that needs to be pre-tensioned to 23,500 lbs.
Because of the connection geometry, I need to grab the 1" bridge strand and pull it up to the pre-tension load.
I have searched and found Klein Tools - Chicago Grips, but they seem to only go up to a safe load of 15,000 lbs.
Does anyone know of a supplier of a cable grip of this size?
RE: guy cable grip/puller
Thanks anyway.
