AM I IN A DREAM WORLD?
Before I begin, just wanted to check to see if I can do a macro that will take a row below and subtract the row above it for each line... However, the glitch is that there are different companies and some contain more rows than others so this would need to start over at that row with company name change.....
Just wanted to get your feedback as if I am in a dreamworld or if this can actually be done?
Thanks a bunch
   Col A       Col B     Col C          Col D
            # OF DAYS
company xyz    AUFER    12/21/2005    0
company xyz    SD    12/21/2005    b3-b2
company xyz    INFO    12/21/2005    b4-b3
company xyz    KA    12/22/2005    b5-b4
company xyz    KA    12/22/2005    b6-b5
company xyz    KA    1/4/2006    b7-b6
company xyz    KA    1/10/2006    b8-b7
company xyz    KAAL    12/22/2005    b9-b8
company xyz    KAAL    1/10/2006    b10-b9
company xyz    SB    12/22/2005    b11-b10
company xyz    SB    1/10/2006
company xyz    AL    12/22/2005
company mno    AUFER    12/21/2005    0
company mno    SD    12/21/2005    b15-b14
company mno    INFO    12/21/2005    b16-b15
company mno    KA    12/22/2005    b17-b16
company mno    KA    12/22/2005    b18-b17
company mno    KA    1/4/2006
company mno    KA    1/10/2006
company mno    KAAL    12/22/2005
company mno    KAAL    1/10/2006
company mno    SB    12/22/2005
company mno    SB    1/10/2006
company mno    AL    12/22/2005
company mno    AL    1/10/2006
company mno    FREI    12/22/2005
company mno    FREI    1/10/2006
company mno    INFO1    12/22/2005
company mno    INFO1    1/10/2006
company mno    FBPL    12/22/2005
company mno    ALOL    1/25/2006
company mno    LT    1/25/2006
company mno    INFO3    1/25/2006
company mno    AB    1/25/2006
company mno    ABFAX    1/25/2006
company mno    FERT    2/1/2006
company mno    FERTI    2/1/2006
company mno    INFPR    5/24/2007
RE: AM I IN A DREAM WORLD?
If you use the lookup function along with IF statements, it can probably be done.  It will take me a while just to input your data into a spreadsheet to find out, so I may not get around to verifying the exact how to.
--Scott
http://wertel.eng.pro
=if(A1=A2, B2-B1, 0)
Thats what I was afraid of.......  I started to do that manually and thought,, OMG, 4700 rows and growing.....oh well, if it is what it is, then so be it... Thanks guys for your input!
Harley
Quote (Harley78:):
Hi Harley:
I couldn't quite follow, so where are you at -- is it going to be a formula based approach, or are you going to use a macro?
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
http://www.energyefficientbuild.com
just a thought . . . try experimenting with the auto filter, subtotals, and pivot table capabilities of excel.  i believe that you find a feature to your satisfaction.  all are within the Data menu!
good luck!
-pmover
"Thats what I was afraid of.......  I started to do that manually and thought,, OMG, 4700 rows and growing.....oh well, if it is what it is, then so be it... "
I don't quite see the problem - enter the expression in the top row, then copy it down to the bottom of the table - wouldn't that fix it in one step?
