MicroStation J (Ctrl+I)
Is there a way to change my settings so that i may view a bearing for a lines direction instead of an azimuth?  It differs from dgn to dgn on this pc and i dont know what it is i need to do in order to find out the bearing.  TIA
RE: MicroStation J (Ctrl+I)
Go to  -Settings-DesignFile then select the working units tab and at the bottom there should be an option to choose between bearing/azimuth/conventional.  Don't forget to go to File-SaveSettings before you close file to keep settings
cveg05, thanks a zillion!!
