Rotating UCS
Rotating UCS
Rotating UCS
Hello everyone,
i'm having a brain fart today.  I'm in MS and i need to change the UCS so that my grid like road system is vertical and horizontal on the screen and not diagonal.  I know how to do it but i can not think of it right now.  Any help would be appreciated.
Juice
RE: Rotating UCS
go to view - viewpoint presents - change to relative to ucs - check ok - then type in command ucs - then on the commandline type "3" - this will ask to define a new ucs - with three points - one for base - one for x and one for y
- then go to view - named views and save it with current ucs.
RE: Rotating UCS
on the command prompt type "ucs"
then select 'view' by typing "v"
The ucs should align with the current view you're on.
RE: Rotating UCS
Another of the many possibilities:
Draw a line in the desired X direction
UCS
Object
Pick the line
UCSIcon
On
RE: Rotating UCS
i did what you guys told me, And that's what i thought i had to do, but the actual drawing isn't rotating, only the xyz arrows in the botton corner is rotating.  How do i rotate the drawing.
Juice
RE: Rotating UCS
The command to rotate the view to match the UCS is "PLAN".
