Exhaust pressure under load
Greetings
pardon my ignorance, I am an electrical engineer, though I probably should have known something as basic as this
Ok here it goes
Suppose we have a mechanically controlled naturally aspirated diesel engine (to make things simpler).
When it is working under heavy load, there seems to be more exhaust noise, suggesting more pressure in the pipe.
This is more subtle in modern vehicles due to better mufflers, turbochargers EGR etc. , but you could very clearly hear it on older naturally aspirated engines , specially if they were unmuffled od the exahust was breached. Not to mention that some of them also threw flames when under heavy load.
So, the question would be:
Under SAME RPM, why is there more exhaust pressure if the engine is working under higher load than if it were under lighter load.
The only thing that comes to mind is that under heavy load, the diesel engine runs rich, which explains the smoke. But
why is there more noise when the engine is under high load?
thanks
Ok here it goes
thanks
RE: Exhaust pressure under load
Also, with heavier load and more fuel, when the exhaust valve opens,
- the charge is still burning, which explains the smoke.
- the charge is at higher pressure, which explains the noise.
If a particular engine is making more smoke and more noise under load than it used to, it may be time for a valve job.
Mike Halloran
Pembroke Pines, FL, USA
So, you mean, a rich mixture (more fuel injected) produces hotter exhaust gas?
Also, you've got me interested, in the valve thing you mentioned. This is unrelated to the thread, but what did you mean by valve job? I assume you meant that valves are opening too early, but how does load affect this? How does load affect timing of valves?
A valve job comprises disassembly, inspection and possible replacement of the engine valves. Exhaust valves normally fail by failing to stay closed, so a little hot gas leaks between the valve face and the valve seat. The hot gas erodes the valve and the seat in a localized area. Every combustion event then produces a jet of hot gas into the exhaust manifold long before the valve is supposed to open. The chamber pressure goes up with load and fuel, as does the leakage flow.
I.e., load doesn't affect the timing of a healthy valve, but the timing of a dying valve is uncontrolled.
Mike Halloran
Thank Mike, that really explains everything I wanted to know
I've been thinking about this question some more, and I have another question about this issue.
Now it's clear why there is more gas going out through the exhaust under load, but what is still unclear to me is this:
Again, we have a naturally aspirated , mechanically controlled diesel engine with unit injection
The engine is in idle, you press the accelerator pedal,
giving it a certain increase in fuel that is being injected in each cylinder, so the engine starts reving up, and just when it starts to do that there seems to be a burs of smoke and noise in the exhaust, which clears up a bit (and quiets down) when the engine reaches stability (when it revs up to a certain RPM).
Now what I don't understand is. If exhaust flow and temperature depends on how rich the mixture is (amound of fuel injected), how come the exhaust quiets down after the engine had reached stable RPM?
I mean the amound of air in cylinder is constant in this type of engine, and so is the amount of fuel after you have pressed the pedal, and the torque generated is increasing engine speed, yet, DURING that process there seems to be more noise for the same amount of fuel injected than AFTER it. (while the fuel amount remained constant, or did it?)
Does that have something to do with the governor?
Does the fuel being injected actually decrese after the engine has reached stable RPM, even though you kept the pedal in the same postion?
I know this post is a mess, so I hope you understand my question.
Mike Halloran
So, that would imply that the governor has effect on all RPM's (providing stabilisation, and making the pedal work more as speed control, than fuel control), and not just as a high-end RPM limit (for safety), right?
By the way. On some engines I've seen a "hose" connecting the "Bosch" unit pump with the the head of first cylinder in the row (just the first one). Now I assume this hose is taking the intake air from one of the intakes to control the governor.
Does that sound correct, or is the hose for something else?
(the engine is mechanically controlled, and N/A)
Mike Halloran
This hose/tube may also be called a smoke puff eliminator.
Franz
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
thanks, I assume you are talking about electronically governed engines, I was just trying to figure out how the most basic and primitive mechanically governed engines would work. But the principle is the same I see.
Anyway, about that hose, franzh, here is the picture,
do you think it's the same thing that you were talking about?
I have highlighted the hose/pipe in red color, otherwise it is a freshly painted engine, so it was a little hard to see
http://free-os.t-com.hr/redmist/hose.jpg
As you can see, it connects just to one of the heads, and seems to be connected near the fuel line, just above the injector
As an engineer, this stuff is much more satisfying than electronic control. But I digress. Yes, noise is generally a function of load at a constant speed because fuelling may vary.
There's still a few million trucks on the road throughout the world with various forms of spinning weight (mechanical) governors.
