Need help with SS tubing...
Hello does anyone know if a 2" diam w/.049 wall thickness Stainless steel tube can be formed with some rings around it. I mean an actual form of a ring around the tube that would increase its dia to 2.090" Im having trouble to find someone to manufacture it for me if you know some fabricators let me know juan.morales@mailcity.com .its not too complicated but it seems that it can't be done please advise.. or advise on any machine that can do it. roll forming rings???
RE: Need help with SS tubing...
done what has the same effect.
What is the purpose of the ring ? Does it have to be
formed from the tube ? can it be a sheet metal or even wire ring attached ( e.g. spot-welded ) ? Do you want to FAX me
a sketch with tolerances etc.? (303)439-8651 ATT:Nick
Does it have to be integral part ? Why ? for sealing ?
What is the temperature etc ?
<nbucska@pcperipherals.com>
