Thermodynamics diagram software
Is there any, if possible freeware, software which could aid in plotting this kind of curves
http://www.rgn.hr/~tkurevi/Slike/NH3.jpg
from known data (temperature, density, enthalpy, entropy...) that I had in Excel spreadsheet?
RE: Thermodynamics diagram software
Since you already have the data in MS Excel, in my opinion, you are almost there.
All what you need to do is set up a few plots in MS Excel, which is an easy job today.
Once you get a few plots up and running, you might consider doing the same in MS PowerPoint so you can have slide shows and maybe jpg and/or gif files.
In the past, plotting was very difficult.
Here are a few examples for combustion products when coal is used as the fuel and standard air as the oxidant:
Gordan Feric, PE
Engineering Software
http://members.aol.com/engware
I just wonder if there is some application that can plot more complicated diagrams than MSExcel, and if that application could plot what I need.
In MS Excel you can get more than one variable on the same plot.
However, if you would like to get fancy plots, you would need to go with a plotting software such as MAHTLAB -- which is very expensive.
Therefore, the trade off is to either stay with MS Office (MS Excel) or go with something like MATHLAB.
Gordan Feric, PE
