Multi-Tag specification
I am having problems creating a multi-tag specification form.  I have set it up so that there are master and slave specifications and so that the non-common fields can be unique.  The first page is the standard form, the second page is notes, and the third page is the multi tag list with whatever fields I allowed to be unique. When I print up the form my Multi-tag list page is blank?  What gives?
Doug
RE: Multi-Tag specification
I am having same problem.  However other users can print the third page with no problems.  IT replaced my ini file with original ini file but did not help.  There is a file in my local directory called Styles.pbd which was updated recently but I do not have the file rights to replace it.  I suspect this is the culprit.  I am trying the print multiple page multi-tag specs but program stops at page three although it always one to add 99 columns to the multi-tag spec?  Can others print your multi-tag specs normally?
My problem just turned out to be that the administrator hadn't given us full rights to the Intergraph program directory.  I suspect yours might be the same.
