Super Flat Check Valve
Dear members,
Our client required "Super Flat Check Valve" on the project piping classification.
What is "Super Flat Check Valve"?
I can just guess that it is the specific brand name of the wafer check valve because client specified API 594 for that valve.
However I can not find any product on the internet.
Please give me your bright knowledge...
Always Thanks....
RE: Super Flat Check Valve
i highly recommend that you request clarification from the author of the project pipe spec.
i am not familiar with that term.
good luck!
-pmover
Seeing how the OP is (aeronautics), the requirements could be just about anything.
What is superflat for the customer, my be a standard product for someone else.
Check-All makes a check valve that is inserted between two flanges.  When the flange is made-up it adds 1/4" to 1-1/16" separation to the flange faces depending on pipe size, material, and pressure class.  2" pipe and below is 1/4" separation.
Good luck,
Latexman
A new term for me also.
What kind of piping system is it going into? Just curious.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Maybe they mean a checkvalve that´s only 1 or 2mm between the gaskets
When such 'special' descriptions occur, most often the originator has a special valvetype from a special maker in mind. Superflat can come from a commercial presentation.
Go to the source!
That said, wafer check valves comes in a number of types and constructions, materials and sealing properties. To mention the most common wafer types: (top) hinged disc, double disc (central stem), disc (axial movement of disc).
The suitability to any process will vary according to type and construction.
A valve, is a valve, is a valve = FALSE  winky smile !
