Need a high static blower for a portable aircraft A/C
I'm building a portable air conditioner for use when servicing aircraft in the hangar. Its only a 5 ton unit(electrical service limitations) and will use 14" flex duct. They have requested that the unit be able to connect to the aircraft ducting (through only an 8" port!), and the aircraft fans will distribute the cooled air throughout the plane. Heat load on the aircraft will only be a few mechanics, and possibly some electrical gear. Plane will be inside the hangar, but at ambient temps up to 100 deg. (Sacramento, CA)
Upon researching existing units purpose built for ground service cooling, I've found the static pressure ratings up to 25"! So I am looking at retrofitting a high static blower into the unit. The aircraft system while in use, if I remember right, is about 7" SP. So I would like to get at least 7-10" pressure out of it, at 2000cfm.
I'm curious about a few things:
1. How much heat do you think the extra static blower will produce, reducing my already taxed tonnage?
2. How much more electrical power do high pressure units draw than lower static blowers?
3. What fan companies have you folks used for special applications?
Any pointers are greatly appreciated!
Chris
Chris
RE: Need a high static blower for a portable aircraft A/C
snip
Fan Hp equation:
air hp = ((flow-cfm)x (head-in w.c.)/6370) x (1/fan mech efficiency)
Contact Jetway www.jetway.com who are one of the larger supplier worldwide on such systems.
