THF causing foam in its water solution?
Morning everyone.
we need water wash THF containing exhaust from a pharmecutical plant. The question is we are not sure if THF solution will cause foam or bubble so makes E+H radar level out of work.
Could you pls. give us some advices?
Thank you in advance.
RE: THF causing foam in its water solution?
I can tell you that we have never seen foaming with THF but we don't have a wet scubber system. My experience is just in washing down equipment, floor washing etc. Never any indication at all on foaming.
StoneCold
