Non-Magnetic Structural Steels
Anyone have a good list of magnetic properties for "non-magnetic" steels?
I have an application for designing a vertical reciprocating conveyor(VRC or material handling lift) typically fabricated from A36 structural shapes (W, L, C, HSS sections). We need to install a lift in a research facility room with MRI (high magnetic field) equipment. They ask that all parts be of non-magnetic steel. I also have to address mechanical interlocks & hardware.
I'm thinking of aluminum, 304 stainless. We have fabricated a 304 stainless lift but I'm not sure of the degree of non-magnatism.
Any references or list would be appreciated.
Fax 414-462-2673
Fax 414-462-2673
RE: Non-Magnetic Structural Steels
We used a lot of stainless steels (don't remember which type) and monel. Almost everything was commercially available which surprised me. That was the reason we were using the magnometer, to make sure they met standard without a huge special order.
Imagineer
