URGENT help for matlab GUI !!!
Hi everybody,
I am a new one here and i need your help. I need to know what is wrong with the program i am writing on Matlab 6.
Its GUI form for solving differential equations and visualization of the results. I am using radiobuttons for switching the solvers but something is wrong with ode functions and i cant help it by myself.
Thank you,
Here is the code:
function varargout = Visualization(varargin)
% VISUALIZATION M-file for Visualization.fig
% VISUALIZATION, by itself, creates a new VISUALIZATION or raises the existing
% singleton*.
% H = VISUALIZATION returns the handle to a new VISUALIZATION or the handle to
% the existing singleton*.
% VISUALIZATION('CALLBACK',hObject,eventData,handles,...) calls the local
% function named CALLBACK in VISUALIZATION.M with the given input arguments.
% VISUALIZATION('Property','Value',...) creates a new VISUALIZATION or raises the
% existing singleton*. Starting from the left, property value pairs are
% applied to the GUI before Visualization_OpeningFunction gets called. An
% unrecognized property name or invalid value makes property application
% stop. All inputs are passed to Visualization_OpeningFcn via varargin.
% *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
% instance to run (singleton)".
% See also: GUIDE, GUIDATA, GUIHANDLES
% Edit the above text to modify the response to help Visualization
% Last Modified by GUIDE v2.5 10-Jul-2007 13:35:51
% Begin initialization code - DO NOT EDIT
gui_Singleton = 1;
gui_State = struct('gui_Name', mfilename, ...
'gui_Singleton', gui_Singleton, ...
'gui_OpeningFcn', @Visualization_OpeningFcn, ...
'gui_OutputFcn', @Visualization_OutputFcn, ...
'gui_LayoutFcn', [] , ...
'gui_Callback', []);
if nargin & isstr(varargin{1})
gui_State.gui_Callback = str2func(varargin{1});
end
if nargout
[varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
else
end
% End initialization code - DO NOT EDIT
% --- Executes just before Visualization is made visible.
function Visualization_OpeningFcn(hObject, eventdata, handles, varargin)
% This function has no output args, see OutputFcn.
% hObject handle to figure
% eventdata reserved - to be defined in a future version of MATLAB
% handles structure with handles and user data (see GUIDATA)
% varargin command line arguments to Visualization (see VARARGIN)
% Choose default command line output for Visualization
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes Visualization wait for user response (see UIRESUME)
% uiwait(handles.figure1);
% --- Outputs from this function are returned to the command line.
function varargout = Visualization_OutputFcn(hObject, eventdata, handles)
% varargout cell array for returning output args (see VARARGOUT);
% Get default command line output from handles structure
varargout{1} = handles.output;
% --- Executes during object creation, after setting all properties.
function m_CreateFcn(hObject, eventdata, handles)
% hObject handle to m (see GCBO)
% handles empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
% See ISPC and COMPUTER.
if ispc
set(hObject,'BackgroundColor','white');
else
set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
function m_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of m as text
% str2double(get(hObject,'String')) returns contents of m as a double
function q_CreateFcn(hObject, eventdata, handles)
% hObject handle to q (see GCBO)
if ispc
else
end
function q_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of q as text
% str2double(get(hObject,'String')) returns contents of q as a double
function u1_CreateFcn(hObject, eventdata, handles)
% hObject handle to u1 (see GCBO)
if ispc
else
end
function u1_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of u1 as text
% str2double(get(hObject,'String')) returns contents of u1 as a double
function u2_CreateFcn(hObject, eventdata, handles)
% hObject handle to u2 (see GCBO)
if ispc
else
end
function u2_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of u2 as text
% str2double(get(hObject,'String')) returns contents of u2 as a double
function L1_CreateFcn(hObject, eventdata, handles)
% hObject handle to L1 (see GCBO)
if ispc
else
end
function L1_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of L1 as text
% str2double(get(hObject,'String')) returns contents of L1 as a double
function L2_CreateFcn(hObject, eventdata, handles)
% hObject handle to L2 (see GCBO)
if ispc
else
end
function L2_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of L2 as text
% str2double(get(hObject,'String')) returns contents of L2 as a double
function alfa_CreateFcn(hObject, eventdata, handles)
% hObject handle to alfa (see GCBO)
if ispc
else
end
function alfa_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of alfa as text
% str2double(get(hObject,'String')) returns contents of alfa as a double
function f1_CreateFcn(hObject, eventdata, handles)
% hObject handle to f1 (see GCBO)
if ispc
else
end
function f1_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of f1 as text
% str2double(get(hObject,'String')) returns contents of f1 as a double
function f2_CreateFcn(hObject, eventdata, handles)
% hObject handle to f2 (see GCBO)
if ispc
else
end
function f2_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of f2 as text
% str2double(get(hObject,'String')) returns contents of f2 as a double
function x_CreateFcn(hObject, eventdata, handles)
% hObject handle to x (see GCBO)
if ispc
else
end
function x_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of x as text
% str2double(get(hObject,'String')) returns contents of x as a double
function xpr_CreateFcn(hObject, eventdata, handles)
% hObject handle to xpr (see GCBO)
if ispc
else
end
function xpr_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of xpr as text
% str2double(get(hObject,'String')) returns contents of xpr as a double
function y_CreateFcn(hObject, eventdata, handles)
% hObject handle to y (see GCBO)
if ispc
else
end
function y_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of y as text
% str2double(get(hObject,'String')) returns contents of y as a double
function ypr_CreateFcn(hObject, eventdata, handles)
% hObject handle to ypr (see GCBO)
if ispc
else
end
function ypr_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of ypr as text
% str2double(get(hObject,'String')) returns contents of ypr as a double
function t0_CreateFcn(hObject, eventdata, handles)
% hObject handle to t0 (see GCBO)
if ispc
else
end
function t0_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of t0 as text
% str2double(get(hObject,'String')) returns contents of t0 as a double
function tend_CreateFcn(hObject, eventdata, handles)
% hObject handle to tend (see GCBO)
if ispc
else
end
function tend_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of tend as text
% str2double(get(hObject,'String')) returns contents of tend as a double
%--- Executes on button press in s1.
function s1_Callback(hObject, eventdata, handles)
set(hObject,'Value',1);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
function s2_Callback(hObject, eventdata, handles)
off = handles.s1;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
function s3_Callback(hObject, eventdata, handles)
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
function s4_Callback(hObject, eventdata, handles)
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
function s5_Callback(hObject, eventdata, handles)
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
function s6_Callback(hObject, eventdata, handles)
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
function s7_Callback(hObject, eventdata, handles)
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
% --- Executes on button press in graphicsplot.
function graphicsplot_Callback(hObject, eventdata, handles)
% hObject handle to graphicsplot (see GCBO)
f1 = str2double(get(handles.f1,'String')); % f1
alfa = str2double(get(handles.alfa,'String')); % alfa
L2 = str2double(get(handles.L2,'String')); % L2
L1 = str2double(get(handles.L1,'String')); % L1
u2 = str2double(get(handles.u2,'String')); % u2
u1 = str2double(get(handles.u1,'String')); % u1
q = str2double(get(handles.q,'String'));
m = str2double(get(handles.m,'String')); % m
f2 = str2double(get(handles.f2,'String')); % f2
% read time intervall
t0 = str2double(get(handles.t0,'String')); % t_0
tend = str2double(get(handles.tend,'String')); % t_N
% read initial datas
y0(1) = str2double(get(handles.x,'String'));
y0(2) = str2double(get(handles.xpr,'String'));
y0(3) = str2double(get(handles.y,'String'));
y0(4) = str2double(get(handles.ypr,'String'));
y0 = [y0(1); y0(2); y0(3); y0(4)];
if (get(handles.s1, 'Value') == 1)
fun=@equation;
[tt,yy] = feval(ode45,fun,[t0 tend],y0,[],m,q,u1,u2,L1,L2,alfa,f1,f2)
end;
if (get(handles.s2, 'Value') == 1)
[tt,yy] = feval(ode23,@equation,[t0 tend],y0,[],m, q, u1, u2, L1, L2, alfa, f1, f2)
end;
if (get(handles.s3, 'Value') == 1)
[tt,yy] = feval(ode113,@equation,[t0 tend], y0,[], m, q, u1, u2, L1, L2, alfa, f1, f2);
end;
if (get(handles.s4, 'Value') == 1)
[tt,yy] = feval(ode15s,@equation,[t0 tend], y0,[], m, q, u1, u2, L1, L2, alfa, f1, f2);
end;
if (get(handles.s5, 'Value') == 1)
[tt,yy] = feval(ode23s,@equation,[t0 tend], y0,[], m, q, u1, u2, L1, L2, alfa, f1, f2);
end;
if (get(handles.s6, 'Value') == 1)
[tt,yy] = feval(ode23t,@equation,[t0 tend], y0,[], m, q, u1, u2, L1, L2, alfa, f1, f2);
end;
if (get(handles.s7, 'Value') == 1)
[tt,yy] = feval(ode23tb,@equation,[t0 tend],y0,[], m, q, u1, u2, L1, L2, alfa, f1, f2);
end;
n=length(tt);
% Visualization
figure(1)
maximize(gcf);
subplot(2,1,1),plot(tt(1:n),yy(1:n,1),'r'),grid on
set(gca,'FontName','Arial Cyr','FontSize',14)
xlabel('????? t'), ylabel('x')
title('????? ?? ???????? x = x(t)')
subplot(2,1,2),plot(tt(1:n),yy(1:n,3),'b'),grid on
xlabel('????? t'), ylabel('y')
title('????? ?? ???????? y = y(t)')
disp('????????? ?????????? ?????? ?? ???????????!'),pause
figure(2)
maximize(gcf);
subplot(2,1,1),plot(tt(1:n),yy(1:n,2),'r'),grid on
xlabel('????? t'), ylabel('x''')
title('??????? ?? ???????????? x''')
subplot(2,1,2),plot(tt(1:n),yy(1:n,4),'b'),grid on
xlabel('????? t'), ylabel('y''')
title('??????? ?? ???????????? y''')
figure(3)
maximize(gcf);
comet(yy(1:n,1),yy(1:n,2))
plot(yy(1:n,1),yy(1:n,2),'b'),grid on
xlabel('x'), ylabel('v')
title('?????? ?????????? v = v(x)')
figure(4)
maximize(gcf);
comet(yy(1:n,3),yy(1:n,4))
plot(yy(1:n,3),yy(1:n,4),'b'), grid on
xlabel('y'), ylabel('v')
title('?????? ?????????? v = v(y)')
figure(5)
maximize(gcf);
colordef none
hs = axes('units','normalized', ...
'position',[0 0 1 1]);
uistack(hs,'bottom');
I=imread('krak2.jpg');
hi = imagesc(I);
colormap gray
set(hs ,'visible','off')
set(hi,'alphadata',.5)
axes('position',[0.40,0.25,0.4,0.4])
comet(yy(1:n,1),yy(1:n,3))
plot(yy(1:n,1),yy(1:n,3),'b'), grid on
xlabel('x'), ylabel('y')
title('?????????? ?? ???????? ?? ?????? ')
figure(6)
maximize(gcf);
colordef none
hi = imagesc(I);
colormap gray
comet3(yy(1:n,1),yy(1:n,3),tt(1:n)),grid on
plot3(yy(1:n,1),yy(1:n,3),tt(1:n),'b'),grid on
xlabel('x'), ylabel('y'), zlabel('t')
title('?????????? ?? ???????? ?? ??????')
function f = equation(t,y, m, q, u1, u2, L1, L2, alfa, f1, f2)
% global m, q, u1, u2, L1, L2, alfa, f1, f2
% f=zeros(4,1);
f(1)=y(2);
f(2)=q/m*(u1/L1)*cos(2*pi*f1*t)+q/m*(u2/L2)*cos(alfa)*cos(2*pi*f2*t);
f(3)=y(4);
f(4)=q/m*(u2/L2)*sin(alfa)*cos(2*pi*f2*t);
Thank you,
Here is the code:
% singleton*.
gui_Singleton = 1;
end
if nargout
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
if ispc
else
end
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
off = handles.s1;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s7;
set(off,'Value',0);
off = handles.s1;
set(off,'Value',0);
off = handles.s2;
set(off,'Value',0);
off = handles.s3;
set(off,'Value',0);
off = handles.s4;
set(off,'Value',0);
off = handles.s5;
set(off,'Value',0);
off = handles.s6;
set(off,'Value',0);
fun=@equation;
end;
end;
end;
end;
end;
end;
end;
n=length(tt);
% Visualization
figure(1)
maximize(gcf);
figure(2)
maximize(gcf);
figure(3)
maximize(gcf);
figure(4)
maximize(gcf);
figure(5)
maximize(gcf);
colordef none
hi = imagesc(I);
colormap gray
figure(6)
maximize(gcf);
colordef none
hi = imagesc(I);
colormap gray
% f=zeros(4,1);
f(1)=y(2);
f(3)=y(4);
