Hole Wizard Major/Minor Diameters
Is it possible to have the hole wizard created the minor diameter geometry and not the major diameter geometry? Here is the issue; I send out parts that are used to cut the geometry along with drawings. If my supplier uses the models to make the parts he could theoretically cut too large of a hole if he does not catch the difference in the drawing. I know that the drawing states that it is a tapped hole but the model shows a hole that is too large (By the way this has not happened yet but I could see it happening in the future especially when I am pressed for time).
RE: Hole Wizard Major/Minor Diameters
Ken
Thanks I appreciate the help. I would not of found that one out on my own.
Brian
Brian
SW 2006 SP 4.1
