Actuator Mounting
Actuator Mounting
Is there any reason we should not mount actuators 'upside down', with the stem of the valve pointing down.
Only reason I can think of is ease of maintenance. It would be very difficult trying to mount an actuator 'upside down'.
Is there a valve reliability issue?
______________________________________________________________________________
This is normally the space where people post something insightful.
RE: Actuator Mounting
That being said it is sometimes recommended to mount steam regulators with the actuator under the pipe. The actuator fills with condensate which acts as a damper, and it is possible to use a buna diaphragm (180F Max) even though the steam may be 400F or more because the heat rises and the diaphragm only sees cool condensate.
Other reliability issues arise from mounting the valve with the actuator horizontal. This puts a bending load on the bonnet/yoke/stem and causes accelerated wear in the guide bushings.
Exception: Butterfly and Ball valve work best with the stem horizontal.
As far as other mounting positions, there are pros and cons to each and you have to determine which is more important. With the stem vertical, it is easiest to remove and reinstall the actuator and ensure the actuator drive and valve stem are aligned. However, with butterfly valves, horizontal is sometimes better as the weight of the disc and shaft is applied to the shaft bearings. Any good mounting bracket should be sufficiently rigid to prevent side loading of the stem regardless of mounting orientation.
