ASTM G48A 316L to SAF2507 weld test
In welds of dissimilar metals as above, what criteria is recommended for an ASTM G48 method A corrosion test. What acceptance criteria would you specify?
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
RE: ASTM G48A 316L to SAF2507 weld test
Steve Jones
http://www.pdo.co.om/pdo/
Steve Jones
I would not use G48 A or B, use one of the newer methods with the acidified solution. They are more repeatable.
It might be even easier to use an electrochemical test for this. You can control the face exposure that way.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
edstainless,
Is there a standard that covers the electrochemical test?
There is a ASTM for it, G150.
I can put you in touch with someone that does this work.
Rust never sleeps
