Imported Sheetmetal Problem
I imported a sheetmetal part from IGES into SW2007 SP3.1.
After making a fully dimension drawing based on this model, I realized that my flat blank size is wrong.  I tried to adjust the k factor in the sheet metal feature in the tree, but to no avail.  I then realized that SW made each of the 13 sketched bends with the default radius checkbox unchecked and the custom bend allowance checked.  After correcting this, I tried adjusting the sheet metal feature again; this time I tried changing the k factor as well as the bend radius.  I also tried changing individual sketched bends.  There was no change to the flat blank size at all.
Has anybody run into this before?  Am I missing something obvious here?  Any and all suggestions welcome.
Thanks in advance.
Fastasleep
RE: Imported Sheetmetal Problem
I have run into the issue you are describing. it usually happens with parts our customers sends parts that are not drawn the best way i personaly find it easier and faster  to redraw it than to sit there and debug it.  if somebody does know a quick way to solve that please do share i am also interested.
Assuming that the finished part is the correct size and you wont need to make any changes to it later:
You can save the finished part out as a parasolid and then open the parasolid file up in solidworks. This creates just a dumb-solid of the finished part, eliminating any bend information that was stored in the previous file.
Now you can re-create the bends back into the solid part with whatever bend radius and k-factor you would like to use. This should give you the correct flat pattern that you are looking for.
-Lou
