gear box advice
gear box advice
I have been asked to find a 1:15 gearbox that can step up the rotation of a 10 KW / ~120 rpm input shaft with an output of a 10 KW / ~1750 rpm 4 pole generator. It's for a small wind turbine.
I have found 15:1 helical and double helical gear reduction units. Can the input/output be changed?
I'm out of my league here. Any help will be most appreciated!
RE: gear box advice
