Drill Depth/Tap Depth Reference
Hi all,
Anyone have a quick web reference for determining how deep to drill with the "pre-tap" drill before tapping, given the depth of thread required? Typically I use hole wizard in Solidworks, but it would be great to have some sort of table to understand.
Thanks a bunch
Failure is a prerequisite of successful design
RE: Drill Depth/Tap Depth Reference
A machinist came to me with a drawing with a hole callout of "1/4-20-.28" I thought this was sufficient enought on a drawing for the machinist to figure how far to drill the pilot hole to attain ~.28" of thread, but apparently not. I know there are quite a few styles of taps so maybe a magic reference table is not available due to the variability of tap  styles.
The depth will also be effected by the type of stud or bolt used.  for example the studs I most commonly see have a one diameter reduced tip.
The required usable thread depth + the length of partial thread on the tap (depends on type of tap and possible manufacturer) + the length of drill point (depends on diameter and angle) + a thread or two for "safety".
Best to make your own chart based on your answers to the variables above.
