Unigraphics Assemblies to SolidWorks
Does anyone has any experience importing Unigraphics NX3 assembly files to SolidWorks? When we open this kind of file, we just see the message: "No Parasolid data".
Any ideas?
Regards.
Hendler
RE: Unigraphics Assemblies to SolidWorks
SW can't import NX3 files yet.
Quote (SW Help Files):
You can import parts and assemblies from Unigraphics II version 10 and higher, including import of Unigraphics NX 2 files.
cheers
Thank you CorBlimeyLimey,
However, SolidWorks can easily import PARTS from NX3. Also, the same behavior is noted when importing assemblies from NX2.
Does anyone have tried to import Unigraphics assemblies to SolidWorks?
Regards.
I've imported a few native UG files.  I always get better results from parasolid.  See if the sender can send you a parasolid.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
The problem is that when I try to import a Parasolid file, the name of the components are lost. For example, If the name of the main assembly is "ASSY_1", then the names of the parts are "ASSY_1-1", "ASSY_1-2, "ASSY_1-3numbers should be maintained.
Parasolid is the only way I know of, unless you find a 3rd party program.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Maybe try to export from UG using differnt versions of Parasolid, and see if one of them just happens to work.
Perhaps there's an option that can be changed in UG.  UG has dozens of options for export, including how components are handled.  Most UG users are only dimly aware of these.
Thats' because an Assy in UG (much like swx) contains no actual solid data, only pointers to the part files so there's nothing there to read. You need to export the UG Assy to parasolid format. Or promote all the parts to the assembly level in UG and resave the file.
Jason
SolidWorks 2007 SP4.0 on WinXP SP2
