Failed soldering test and wonder why..
Dear Engineers
Sorry that this is about soldering, it's just that i'm an electronic engineer inbetween jobs....today a recruitment agency kindly sent me for a soldering test at a local electronics company so that i could hopefully do some soldering work till the next electronics job comes up...I failed the soldering test -but believe that my poor solder joints were due to the company's poor equipment rather than my technique. I am worried that the agency will now not refer me for other soldering jobs....I would be very grateful if you could analyse my (following) letter to the agency and provide any thoughts on whether you believe i am correct to criticise the company's soldering set-up. The company was a high-tech comms company and there were no other solderers working there -just electronic engineers. The soldering test involved surface mount 0402 resistors and capacitors.......(ive subbed in  the name "electro-save" for the comapny's actual name)....
Thankyou for arranging todays soldering test at Electro-save. I fully respect their decision not to employ me and have no complaint whatsoever, -whatever their reasons for deciding against employing myself. I am extremely grateful for their time and consideration.
With reference to this Electro-save soldering contract where I was not selected for employment, I am hoping that I can provide some kind of assurance that my soldering skills are not as bad as my performance at Electro-save may suggest. I am hoping that your office may not be deterred from putting me forward for such soldering contracts at other companies.
During the soldering test, I noticed that the solder was not “wetting” or “running” as it should. “Wetting” is where the heated solder momentarily becomes “water-ish” and flows over the work, -intimately clinging itself to the shapes of the work. When “wetting” occurs, one sees the solder flow over the work, and there is sometimes  a momentary glint of light as  the solder “envelope” changes shape and momentarily reflects light toward the eye. –This did not occur at Electro-save, -the solder merely “sludged” without flowing. –I feel that this is in some way due to the set-up of the soldering system at Electro-save. It is indeed possible to learn to “sludge-solder” with reasonable results, though it is not recommended and is bad practice.
I have previously soldered such things as 0.5mm pitch ICs with excellent results. –Indeed, when soldering these components, I noticed the solder actually starting to flow up the pins of the IC’s , as it should. –At Electro-save, such flowing of the solder did not occur.
-At Electro-save, even when I simultaneously touched the solder onto the solder_iron_tip and the pad as an experiment, the solder did not flow over the pad as it should –instead the solder just “sludged-up”. –This suggests a problem with their soldering set-up.
Firstly, the “sludging” seen at Electro-save was partly due to the fact that the PCB pads on which I had to solder were slightly “yellowed” with oxide. Usually, flux-cored solder would act so as to remove this oxide coating, allowing the solder to “run” and flow over the work. It was evident that the solder with which I was provided did not contain much flux, -since there was an absence of flux residue on the work after it had been soldered (flux residue can easily be cleaned off with a suitable cleaning agent) –This lack of flux was one reason why the solder would not flow properly for me.
Solder that has a sufficient helping of flux in its core produces fumes with a distinctive smell. I did not notice this smell with the solder that I was provided with at Electro-save. –Flux was always going to be necessary with the slightly “yellowed” 0402 pads that I experienced at Electro-save. I feel that this may have been why the solder would  not flow properly for me.
Electro-save staff did however provide me with a flux pen, -though this was dry of  flux. –This is a problem with flux pens, and is the reason why flux-syringes provide for better application of flux. (I was not provided with a flux syringe at Electro-save). Alternatively, a pot of flux and a fine point to allow application of flux to the pad is OK.
Another reason that may have prevented the solder from flowing adequately at Electro-save, was the fact that the solder was slightly too thick in diameter and the solder_iron_tip was slightly too thick.
Also, for soldering 0402 components, one really needs a soldering iron with a settable temperature so that the tip temperature can be optimised for the work. Also, the tip temperature should preferrably be maintained constant by a temperature feedback system. (This prevents the solder tip from cooling when applied to the work) The irons at Electro-save had no settable temperature. I am unsure as to whether or not the irons at Electro-save had temperature feedback control.
PCB’s with pads meant for hand soldering sometimes have “necked” pads to facilitate hand soldering. (A “necked” pad is a pad for which the adjoining PCB track becomes narrower just prior to meeting with the pad) –The “neck” is good as it prevents heat from the iron “running away” along the adjoining track. –If an iron has no temperature feedback control, then there is no correction for the cooling of the tip that occurs when the tip is applied to the non-necked pad. –Under this circumstance, the solder may not be heated enough to allow it to flow properly –and insufficient solder flow was what I actually experienced at Electro-save.
Most PCB’s are populated using flow solder machines (as opposed to hand soldering), and “necked” pads are not necessary, as the work is sufficiently heated by the solder flow machine. I suspect the PCB’s with which I was provided at Electro-save had  non-necked pads –as a consequence, I suspect that the work may not have been sufficiently heated by the iron that I was using –thus causing  a deficiency in the flow of the solder which was heated with what may have been a non-temperature_regulated iron.
Another thing that worked to my disadvantage was that the solder braid with which I was provided was much too wide. Solder braid should be no wider than the widest dimension of the pad being cleaned of solder. –However, the braid with which I was provided was over 4 times wider than the widest dimension of the 0402 pads.
-Solder braid that is too wide can damage the pad that it is being used to clean, since it conducts more heat away and may cool and stick to the pad, resulting in damage to or removal of the pad.
The soldering iron with which I was provided also had a deliberately bent tip. These bent tips can sometimes be useful, though if the iron is not at the right temperature, these bent tips are less than useful. –This is because solder tends to “clag” up in the bend of the tip, -this “clag” of solder then acts to consume heat from the solder tip,  meaning that the work is not heated to the temperature that it should be. Also, the lump or “clag” of solder tends to make the tip less fine –and the tip needs to be finely pointed for soldering 0402 capacitors and resistors.
Also, since the “clagged” solder becomes trapped within the bend of the tip, it is rather difficult to remove with the solder sponge.
At other electronics companies where I have selected  soldering irons, tips, solder and flux myself, I have had no trouble soldering 0402 resistors and capacitors. –For some reason, the solder just would not flow for me at Electro-save. I did my best to try and keep the tip clean (even though the solder sponge was dirty) and applied a light tin to the solder_tip prior to appying the tip to the work.
Another problem was that the tweezers with which I  was provided were magnetised –this made it awkward to grasp the 0402 capacitors without the capacitor swinging up to the tweezers and sticking to them in the wrong position. One then had to handle the 0402 capacitor to try and get it off the tweezers…-thus putting sweat onto the capacitor contacts, which does not assist in its subsequent soldering.
Soldering systems for hand soldering 0402 surface-mount capacitors and resistors should be srupulously specified. At Electro-save it was not possible to set the solder tip temperature –also there was no indication as to what the solder tip  temperature actually was.
At times I actually noticed that the solder was “spiking” up from the work –this actually suggests that the iron was too hot. (I  did not apply the tip to the work for too long a time) -However, there was no means by which I could adjust the temperature of the soldering iron. I also sometimes noticed that when the solder was simultaneously touched to the pad and the component and the solder_tip, -the solder actually just streamed up the solder_tip itself rather than going over the work –This again suggests that the solder_tip was too hot for soldering to that particular pad.
Please don’t let this seem like sour-grapes, -it’s just that I have not experienced such problems with soldering in other companies, and would hope that your office may not be deterred from seeking soldering contracts for myself at other places.
RE: Failed soldering test and wonder why..
I would say that you should set up an appointment to talk to your representative at the agency in person. The agencies tend not to have very technical people working there and your letter has a LOT of detail that will just go over their heads.  Take the letter with you so that they can put it into their records, but talking face-to-face will go a lot further.
It's possible that to pass the actual test, you would have to put down the tools, turn off the iron, and say: "
- The flux pen is dry.
- The parts are corroded.
- The pads are not designed for hand soldering.
- The iron is the wrong shape.
- The sponge is dirty.
- The iron temperature is wrong.
- The tweezers are magnetized.
.. etc.
... and for all these reasons, I refuse to make a bad joint."
Print that letter out on nice paper.  Then shred it.  Don't send it.
Just remember this:  Sometimes the test is not what you first think it is.
Mike Halloran
Pembroke Pines, FL, USA
Could it have been unleaded solder, ala RoHS?  That won't make for a pretty joint...
Dan - Owner
http://www.Hi-TecDesigns.com
It's too long a letter to send to the agency.
If the job is soldering then you needed to correct their setup on the spot.
I have never gone below 0603 myself (with an iron) but you certainly get problems when the solder won't wet the iron's tip. recently, even using tip cleaner the solder still wouldn't wet the tip. I had to take some wire wool to the tip, which shows the level of desperation!
The letter glazed my eyes over and I actually cared..
I wouldn't send the letter.
And if you're an EE you shouldn't be soldering piece work. Period!  You will taint yourself and your resume horribly.
Keith Cress
I would send them a short letter stating that you are an experienced solderer and the  failed test at Electro? was, in your opinion due to the faulty equipment provided.  And that you would like to go on at least one more soldering test.
I had a similar problem once when I took an analog-digital circuits test  They said I did poorly on the analog part.  The examiner did not believe me (she knew nothing about electronics, just how to score a multiple choice test).  So good luck, the deck is probably stacked against you.
I suspect that MikeHalloran is right.  Nobody wants to inspect hand-made SMT solder after the job, especially in domains where low failure rate is paramount.  A telco company will not accept subpar equipment or off-standard procedures and would have welcomed employees who are able to detect it before the work is done.  If he is wrong, then the telco company will quickly find another recruitment agency after they get employees who just do what they're told to do, right or wrong.
A resume that shows that you're not afraid of soiling your hands is not a bad resume to my eyes. (Unless you dream of jobs like simulating communication protocols on a supercomputer.) It may lead you to positions like production engineering or management as the years go by.  There's always demand for such positions.
All above points being valid, it may behoove you to send a short and sweet note (similar to what Mike listed) to the hiring company rather than the recruitment agency.  Ask that they reconsider their position on not hiring you, and mention that you wished to do the best job possible given substandard conditions and equipment, but understand that any work created under such conditions would be subpar, at best.  Mention you would always bring this to the attention of management.
I'm in agreement with Mike that you may have failed the "true" test by not bringing it to management's attention at the beginning... but mentioning it after the fact would show you were at least aware of the problems, and that's probably half of what they're looking for.  Just don't make the same mistake again...
Dan - Owner
I agree.  The true measure of an employee is what they do when things go wrong.  The fact that you did a sub par repair without saying anything indicates you would do it in real life to get something out the door to meet a schedule.  Having thought about it, that was a pretty neat test.  I have had production people that keep churning out product when there is a problem and not notify engineering. Quality is the job of everyone.  About the only thing you can do is move on and learn from the experience.
To add my own two cents here, I agree that the letter is WAY too long and I stopped reading it about halfway through.
My initial reaction was that you should have brought all these issues up, during the test, indicating that you couldn't do appropriate work with these tools and or conditions.  Whether or not this was the intent of the test, I can't say, but it is a clever idea.
I also agree that you should have at least some sort of note with you, a condensed version of what you have, and try to get a face to face meeting.
ItSmoked also has a good point.  If you start working as an assembler, you run the risk of getting pigeon holed and it can be very difficult get out of that role and back in to an engineering role.  At the same time, having the ability to solder the boards can be a very good thing, just not as a full time position.
Thankyou for your replies. I've certainly learned a lesson here. i think Mike Halloran was right with "Sometimes the test is not what you first think it is."
At the time, it was obvious that my work samples weren't going to a customer and i just assumed that they wanted to see me do my best with the kit that they provided. -But now realise my error.
I should have 'twigged' it when i first used the tweezers -it was horrendous! -the 0402 caps were literally repeatedly flying up to them and it was extremely awkward.
One of the engineers sat about 10 metres away kept making "sizzling" ("Tssssss") sounds whilst i soldered and i now guess he was trying to drop hints to me. -or having a laugh about my ignorance.
They also provided a large desk-mounted microscope for me to examine the 0402 solder joints with. -However a small hand-held eye-glass is far better..it allows easier "panning" around the joint....also, it's much quicker to use a hand-held eye-glass since "panning" round an 0402 solder joint on a PCB and staying in-focus using a desk-mount is very difficult and completely impractical.
I still GREATLY prefer my stereo binocular microscope.  I don't need to pan around a 0402.  But when I zoom there is no defect not blantantly obvious.  I solder 6"x7" boards thru that microscope with great ease and acuracy.  Can you tell I love it... LOL
Keith Cress
It was customary to send a thank you letter to the interviewer. These days people don't even dress up.  If you haven't do so yet, it might be a good idea to send one.  Say you know why you failed the test and it was a good lesson that quality should never be compromised.  A little humility might get you a call back in the future.
Too long a letter!
To convey all that you should be able to say it in just one fifth of that lengthy letter.
Agustín Tomás
"it's a poor workman who blames his tools"
sad but true
