How can I find out what type of lens I have?
How can I tell which lens I have in an older laser? The manual states that the laser came with a 2.5 and 3.75 lens, but it has instructions on how to dismantle and re-mount a 5" lens as well. So how do I know which one is actually in the machine?
The answer is probably just as obvious as I think it is, but I want to be very very sure.
Thank you for your help!
RE: How can I find out what type of lens I have?
However, if you look at the box where the lens came from, it should tell you everything there is to know about it. In your case, and I assume you are the same guy who has the LC1212, your machine came standard with 5.0" Lenses. You have an adapter for a 3.75" and a 7.5" also.
TTFN
