Design for Thru Hardening or Not?
I have been thinking about the post on 1045 vs. 4340
http://www .eng-tips. com/viewth read.cfm?q id=190661& amp;page=2
and have some questions about design methodology.
Lets just say one is designing a machine component and is considering a range of steels. Why is it totally necessary for the component to be hardened all the way through? I understand that a tool such as a die/punch where the tool will be ground throughout its lifetime for sharpening purposes and consistent properties are desired through the tool cross section.
Take for instance a machine shaft or a component in a high speed machine under moderate impact and light wear. If one uses a steel that will not through harden the part, will there be favorable compressive stresses in the surface of the non-thru hardened component similar to a carburized part? If the surface gets hard enough with a partially hardened part isn't that enough? Wouldn't a fully through hardened part be more inclined to fracture?
I remember reading an ad I think in a trade magazine where someone redesigned a large track pin for Caterpiller. CAT had been using an alloy steel for the pin that was carburized then Q/T. The new pin was made from 1065 if my memory serves me well. The point the article made was that after heat treat the 1065 pin had a softer core that assisted in fatigue resistance and the harder surface was sufficient to withstand service conditions. Also the 1065 pin was cheaper to make and heat treat.
http://www
RE: Design for Thru Hardening or Not?
My hunch is that the Cat part mentioned was seeing some wear and the load was in pure shear. It might be different if the part say impact loading.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
