Thermal distortion compinsation
I have a mechanical instrument comprising a polycarbonate frame about 120mm and wheel 100mm dia mounted on miniature ball bearings. I am running into difficulties with thermal distortion causing extra friction on bearings. I am looking for design guides to minimise or compinsate for thermal distortion.
Any help would be apprecisted.
RE: Thermal distortion compinsation
www.usatolerancerings.com
Russell Giuliano
Check http://www.matweb.com for you specific PC.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
Response if conjecture is correct: Make one half just a cover, but both bearings in the other housing half, so their temperatures track each other and they are naturally aligned. You will probably have to destroy the symmetry of the wheel, too, offsetting the web to clear the bearing housing.
Response if conjecture is not correct: Tell us a little about the problem, already.
Mike Halloran
Pembroke Pines, FL, USA
