Online Tie-In for DCS/SGS
I'm doing a cogeneration expansion project. For the existing cogen project we use Honeywell Experion for the DCS/SGS to monitor and control 4 trains of GTG/HRSG and 1 train of STG.
For the cogen expansion project, we plan to install one additonal train of GTG/HRSG. Hence we need to upgrade and install additional DCS/SGS software.
Is it possible to carry out the tie-in work online without shutting down the existing plant?
ppm
ppm
RE: Online Tie-In for DCS/SGS
I have worked on many "hot cut-over" jobs. It requires more planning and equipment, obviously, as well as experience. The key for us was a very detailed cut-over plan, and a lot (and I mean a lot) of detailed communications and updates all along.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
