question about home renovations
I am sure many of you watch all of the home improvement shows (either by choice or force).  I often see people just adding sliding patio doors or french doors out onto a new deck where there was only exterior wall.
Obviously a header is sized for this application.
The question I have is regarding the lateral resistance of the house.  I have never seen any of these shows make any mention of the lateral system.  How does one go about determining if the wall you are about to cut a 6'x8' hole in is a shearwall??  I would expect that whoever designed the house would have used every exterior wall of the house (solid walls, and solid panels between walls) as a shearwall in an effort to get the unit shear on each wall as low as possible.
That being said, if you start cutting holes in those shearwalls and making them essentially worthless, it seems to me that someone should be verifying this is acceptable rather than simply sizing a header for vertical loads.
Can someone tell me if I am missing something?
RE: question about home renovations
The answer to your question can be very detailed or simple...I'll go simple and say I have never seen a home's lateral system fail.  If a house experiences enough lateral force on it, it will likely fail components before it fails the shear wall.  Therefore, IF the house was originally designed with certain shear walls, then it's likely even if you take out an entire wall there will be enough redundancy in the system.  I mean, legally you can design shear walls made of drywall, so there are likely some walls playing into the system that arent even being considered.
I would recommend asking this question on the ICC website's bulletin board.  Many more code officials cruise that site and would be able to give you a better answer about the verification process.  I'd think some locations will require permitting and may actually check this, but surely the majority don't...and I doubt anyone is going to force Mr. Average Joe Voter to go out an hire an engineer to verify if his house will fall down if he installs a patio door.
Oh yea, and also, another bothersome thing I always see on those home improvement shows is when they construct a 2 story vaulted room by just stacking two sets of stud walls on each other without designing a horizontally spanning header mid height.  It just doesnt look like it can work, but it does all over the US
I don't agree that it is OK not to check the lateral system because there may or may not be some redunancy in the construction.  That is what Atomic seems to imply.  If not I apologize, but either way that is another thread.
I've often wondered the same about home shows.  I suspect they don't show you all the engineer and legal requirements because it's too boring (?), but we the viewers don't know.  I hope someone is checking all the structual and geotechincal requirements.
I like that part about "choice or forced".  The forced part sounds familiar.
UcfSE-
Thanks for reinforcing my concern.  The next question I have is how would one go about checking without knowing how it was designed to begin with?  Is it a matter of assuming all exterior walls can act as shearwalls and checking to make sure the remaining capacity is sufficient?  I am just thinking that this seems like a monumental undertaking.  You would have to verify anchorage of diaphragm to shearwalls, verify fastener pattern on shearwalls, blocked or unblocked shearwall, sheathing thickness, etc....  It seems like it is far more intrusive than is shown on t.v.
..StructuralEIT
I can assure you that you are not missing anything. Any skilled carpenter, framer or bricklayer (at least within Scandinavia) would ensure the wall was structural sound after such a remake, putting in extra steel or wood beams and supports if necessary.
To do otherwise is against law and rules in Scandinavia. And also in the US you have areas where the extra snowload on the roof (or a stormy day) could give some surprise after the sunny summerday when the TV-Team left....
smile
I would start by looking at the prescriptive requirements for Braced Wall Lines in the IRC and see if the minimums are still being met with the new opening in place.  I don't thing the majority of homes in the United States are built with true shearwalls with hold-downs and the like.  Maybe in high wind or seismic areas, but even in these areas, there are prescriptive "recipes" for residential construction.
That being said, I see lots of additions being put on where 20 foot sections of rear wall (at the end of the house, no less) are removed to open up to the addition.  I don't think the code officials are even looking at bracing requirements when they issue a lot of these building permits.  Usually they just want engineering on the 20 foot header.  This is in Maryland, by the way.
It's difficult to force someone to get engineering there not being required to have.
gerhardl-
With all due respect, I don't think many (if any) skilled carpenter, framer, or bricklayer is capable of assessing what I am talking about.  "Structurally sound" is not necessarily what I am talking about.  That, to me, means none of the existing framing is rotted and is in generally good condition.  That does not mean, by default, that the "new" lateral system is capable of handling the loads.
I also have no (read little) doubt about the sizing of most headers over these openings for GRAVITY loads as this is pretty straightforward.  The question I am asking is in regard to lateral loads.
ctcray-
Wow!!  That seems almost negligent.  Obviously not on any engineer's part (if one is not used), but.... my goodness that is scary.  I would think taking out 20' of shearwall would change things drastically, from what was mentioned above to adding significant torsion by moving the center of rigidity (as a result of eliminating a large portion of the lateral resistance).
Also, I understand that many homes don't have hold downs, but that is more a function of the dead load on the shearwall and not that it is not a true shearwall, correct?  Once you take out such a large wall, and throw more load into the other walls, isn't it quite possible that some of the other shearwalls that didn't require hold downs before will now require them as a result of the larger loads being dumped into them?
all you can do is recommend that they get it looked at, if they refuse to take your professional advise then thats their problem.
That said, if it is not in a hurricane/earthquake region then it will probably have much more racking resistance than it needs anyhow.
csd
ctcray is exactly right
"It's difficult to force someone to get engineering there not being required to have."
Quote (UcfSE):
Saying that, I watched one of these home improvement programmes where a couple were rebuilding a fourteenth century castle in England.  The interior was full of debris and plant life up to about the first floor level (second floor in the US).  They dug all the rubbish out and arbitrarily shored up some interior walls.
At this point the camera crew legged it out of the building to the sound of creaking.  Shortly after one of the interior walls collapsed after the shoring gave way. I think they were lucky the entire building didn't come down.
Have you guys seen that show in North Carolina (trademark properties)?  These guys flip houses in like 4 days.  I am pretty sure they do not have permits and they tear a lot of things apart without PERMIT!
http://www.swijetty.com
Sea Water Intake and Jetty Construction
COEngineer,
Yeah, I get "forced" to watch them.  They're pretty amazing with how fast they move.  I think they're in South Carolina, actually.  While I was watching late last night, I saw them tear into some trusses to create a vaulted ceiling.  I was somewhat stunned.
Well, of course you will make money if you dont have to pay for permit (no down time) and you dont have to pay engineer and architect fee.  Just tear it apart, put new opening, add SQ. FT. and call it good.  KACHING!!
i like it when they do get the building inspector or a small time engineering consultant on the show. I haven't seen one of them comfortable working in front of the camera.
Fear of armchair engineers, contractors, and inspectors is at play. :)
I don't agree that putting a patio or french doors into a house makes a shear wall worthless. In times of high shear you would expect that the door would be closed. (And this is a reasonable expectation, just like when you use load factors, you do not have a high weather load and a high live load at the same time.) If a door is installed properly, I believe that it will not significantly reduce the capacity of the wall when the door is closed.
I would think that the glass would not perform well under shear.
Str'lEIT, that is exactly the problem you would have unless you were the engineer for that job already.  Even if you have the plans, unless they are as-builts you never know what you really have.  That is common to remodels and additions in general.  You would have to have a way to verify what is there.  If you assume something and it has a problem later on, guess who is in the fire for it.
With masonry you may get away with assuming every wall is a shear wall provided it is detailed properly.  In that case you may just need a bar at the end of the wall which is typical, at least in my area.  With wood, there's more to it as you know.  If there is any uplift on the shear wall ends you'd need a holddown.  So it's not quite as simple as saying every wall is a shear wall.  That's part of why it also isn't as simple to say you have extra capacity with the interior walls.  If there's no hold downs and the wrong screw pattern (if they even put screws in it!) for those gypsum walls then you have a problem.  Yes there is some sort of capacity but you have no way to evaluate it with a given degree of confidence.
well, all walls will resist some shear, whether they were designed as shear walls or not.  Not like the wind picks and chooses which walls to shove.  Question is how much.
Like UcfSE said, all the unknowns are an inherent issue with additions and remodels.  Here in CA, you DO have to get engineering to cut a hole in a shear wall usually.
Generally, it boils down to some educated guessing regarding construction of the era/region, what little site investigation you can accomplish pre-demo, and making some guesses with a whole lot of 'contractor to verify' on the plans.
One approach I've used is to calculate the CAPACITY of the wall (if possible) pre-modification, and then retrofit enough to maintain it - and not worry about what it may or may not have been designed to resist.
CJSchwartz
Glass is not the best material to use to resist shear, but that does not mean that is does not have some shear capacity. I am just saying that having a patio door will not make the wall worthless. And a properly framed in patio door will not significantly reduce the shear capacity, unless you have a very small house and a very large door.
DWHA-
If you have a 30' wide x 9' high shearwall (assume an entire wall is available).  Now you cut a 7' x 7' hole in the middle of that wall.  How will you transfer shear across that opening to make this act as "one" wall?  If you assume (2) shearwalls (which is perfectly reasonable), the unit shear will increase only marginally, but you have such a smaller "d" now that I would be amazed if a hold-down wasn't needed.
I don't think you can just cut an opening that size in the wall and assume that it will not significantly affect the lateral resistance of the building.  Even if you look in Breyer's book, the shear on perforated shearwalls is considerably higher around the openings and is accounted for in the original design.  Unless you tear off the siding and take the steps necessary to achieve this extra shear capacity, the segmented shearwall is the way to go.  That being said, the "d" is getting cut down immensely as stated above and this has real consequences that can't be rationalized away, IMHO.
So are you ignoring any and all strength of the door? If you are ignoring that then I will agree with you. But, the door itself does have shear strength and forces will be transfered thru it. You can neglect it, and that is a conservative approach. But that does not mean that is wrong to say that the door does have some capacity.
Do you think that everytime that a patio door is added the contractor takes measures to prevent this. No, it does not happen. That being said, Have you seen a house that has failed in this way prior to other significant failure?
DWHA,
Structural items are required to be ductile, something glass is not.
DWHA, what exactly is the capacity of the door?  Is it connected correctly to transfer load?  Has the manufacturer designed the door for the racking load you are requiring or accounting for?  There is also csd's point about ductility.
I don't agree that it's ok to do what you want because something else will fail first anyway.  That only means that more than one member or system was incorrectly designed.
DWHA-
I agree that the door may have some shear resistance, but it is not something that can be counted on (there is no way to quantify it).  Also, as csd72 points out, the glass is not ductile.
No, I don't think a contractor takes measures to account for this - that was the whole point of my initial post.
Also, I am not sure that just because I personally haven't seen this result in a catastrophic failure makes it "right".  It is quite possible that there has been enough redundancy in the system to make up for it, or maybe the building hasn't experienced its design loads...  either way, I don't think we, as engineers, can just say it is ok without investigation.
I have seen houses with cracks (in the drywall) radiating from the corners of the doors in situations like this.  This may or may not be directly attributable to what we are talking about, but......
That being said, I was trying to figure out if these guys are doing something behind the scenes that we are not seeing or if this is a nightmare waiting to happen.  If the first is true, I was curious as to what went in to checking this kind of thing (as you can see from some of my previous posts in this thread).
sounds to me like this may be one of the main reasons it is not required. Because, engineers don't want to touch it (or at least not for the crappy sum that the contractor or homeowner is Begrudgingly willing to pay for the piece of paper).
all the time, I get cold calls to look at existing residential foundations to sign-off on them for loan approvals.  Our competition is rushing to shmooze me for all the "referrals" i give them.
I think it's pretty safe to say that lateral stability isn't checked for your average door installation.
I think in this part of the world (mid USA) all you need to build houses is a pickup and a circular saw:)
regards,
Mike
The only show that routinely refers to permits,  architectural, and engineering help is the show "Holmes on Homes" with MIke Holmes. He always comments if the builder or remodeler didn't get permits or engineering help and that is part of the problem the homeowners have.
Another emphisis he has that the code is only the minimum requirements and may not completely fill the bill.
One of his latest shows he had Weyerhaeuser come in and design a beam for the first floor that carried the load bearing wall for the second floor.
StructuralEIT,
I have often wondered the same thing.  I practice in Southern California and if we have a project that only moves a window/door even 6" within a wall that could possibly be a shear wall, we have to look at the lateral system that "might" be there.  If we don't - the building official will ask us to.  You never know when that 6" made the holdown that was there obsolete.  The homeowner is always happy about this process but it is often less expensive than stripping down the whole house to verify for sure where the existing shear walls are (or if there are any, depending on the age of the house).
I'm sure that if these shows do look at the lateral system, it is just not shown.  After all, the parts that would be very interesting to us, just isn't to everyone else.
I guess my concluding question is, "What would you do if you were doing a renovation to your own house?"  Would you size the header for gravity and not give a second thought to the lateral implications, or would you start trying to check out the capacities and how exactly would you go about it?  Would this change if you were doing a 30' opening on a 40' wall into a new addition (what was a lean-to with no lateral system of its own) compared to a 7' wide opening for patio doors?
Looks to me like it is a simple 3 step process.
1. calculate the load on the wall ignoring any contribution from internal walls.
2. Calculate the strength of the remaining wall using typical wall sheathing (note assumptions on sketch to be confirmed).
3. Calculate and specify the additional tie downs needed on either side of the opening. Also note edge nailing required to double studs.
csd
Another thing to keep in mind is a lot of jurisdictions don't require a structural engineer for single family homes less than a certain size.
