Liquid color change brown to clear
To symbolically demonstrate the neutralization of a waste water stream I want to have a transparent vessel of water change from brown to clear after adding a clear liquid. I have found some indicators that will go from yellow to clear that I will use in a pinch (p-nitrophenol) but I would prefer brown. Any tips? Maybe with potassium iodide?
tia, Peter
RE: Liquid color change brown to clear
Perhaps tea?  May not turn completely clear, but it is a brown pH indicator.
Aaron A. Spearin
ASQ CSSBB
www.Engineering6ss.com
"The only constant in life is change." -Bruce Lee
Thanks for the tip. I didn't know tea reacts to pH.
The setup is working now with a diluted iodine solution. After I add sodium thiosulfate it reacts and the solution goes clear. Your suggestion is a bit less poisonous though.
Peter
Maybe you can use an iron laden solution. The addition of HCL will dissolve the iron. Iron is reddish brown.
Unfortunately "brown" isn't a pure colour:  you need orange and green, or perhaps red and green, to get that sort of "dirty" colour.  Maybe fluorescein (going from colourless to fluorescent green from pH 4 to pH 4.5) mixed with ethyl red (going from colourless at pH 4 to red at pH 5.8) would give you the brown colour at neutral pH you want.  Add acid and voila, colour goes away- but probably not leaving a totally clear and colourless solution.  Neither of them are particularly toxic.
