Weldment Detail
Weldment Detail
I'm using the weldment tool for a complex weldment and using the relative view tool to create individual details on seperate drawing sheets. Does anyone know of a way to link notes on that detail sheet to the cut list custom properties? If it were done as assembly and I was detailing a single part, I would just use $PRPMODEL:"Description".
RE: Weldment Detail
Stugots
Mechanical Designer
SW '06 SP5.1
RE: Weldment Detail
$PRPWLD:"DESCRIPTION"
(similar process to what you do with assemblies)
RE: Weldment Detail
RE: Weldment Detail
Stugots
Mechanical Designer
SW '06 SP5.1
RE: Weldment Detail
RE: Weldment Detail
From your description you are going to create a detail of say "left front plate" or something like that and you want to put a note on detail that will be fed back into the cut sheet on the first page. Is this correct?
I think it may be easier for anyone to help if we get maybe an example of what you are trying accomplish.
RE: Weldment Detail
