Petrol-electric engine layout
I work in mechanical engineering but am undertaking a personal side project in automotives for my mother who is going to have knee replacements in a short while. I have begun the project but have realised my shortcomings in the automotive field.
I am looking for advice in petrol-electric power. My vehicle is light (under 100kg) and is not at all required to reach high speeds. I have a four stroke engine and have begun the chassis etc. I would like advice from anyone who knows what sort of electric engine and layout (electric at wheels or on main shaft etc) I should be looking at and how I should go about constructing it.
Any advice at all is appreciated
RE: Petrol-electric engine layout
So, you don't know how to build it, but you already know its mass?  And it will have two prime movers, and energy storage for both?
At least one of us is confused.
Hmm.  100kg would be a reasonable design payload for an electric wheelchair.  Is that what you meant?
Mike Halloran
Pembroke Pines, FL, USA
Perhaps it will help if you tell us what sort of thing you wish to build, and maybe a few performance criteria (How fast, how steep a hill at what speed, what payload, etc), and what sort of engine you have in your possession.
I have talked to a manufacturer of electric sit-on scooters in the past. He told me that frankly he doesn't need efficiency, there is enough oomph in a standard 12 V traction battery to satisfy his customers.
So, have you considered just an electric drive, or are you sure you need the added range of a petrol engine? Why not start with an electric one and add the petrol engine and generator later?
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Try looking at golf buggies for ideas. They are probably twice the size you need with enough performance and range. With the golf buggy drive train in your device, this performance and range would increase significantly with the lighter single occupant device vs the golf buggy.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I've worked in the personal mobility field (wheelchairs and mobility scooters) in the past and here a few things to keep in mind.
As Greg Locock said, do you really need petrol? and if you are going petrol why bother with the electric side of things?
From the electric side of things electric scooters use 2 x 12v deep cycle batteries in series to give 24v. the controllers can handle from 70 to 160Amps for transient loads (Acceleration, kerb climbing etc.) If you use 50% as an efficiency for the motor/gearbox thats up to 2hp power output. The acceleration some scooters are capable of when the programming is wound up is impressive. Scooters with a range of up to 35miles are available.
Electric motors each wheel will require some way of varying the speeds individually  with respect to steering input if you want any real success at turning corners.
Single motor on axle will require a differential of some description for the same reason. Will also lose all regenerative braking if an open diff is used and a wheel leaves the ground (usually when trying to avoid a collision).
Braking, mechanical or regenerative braking, or both? (electric motor is used as a generator to recharge batteries while also provide braking force). Common on bigger/faster mobility scooters is a mountain bike brake disc and caliper on the rear axle as a secondary/backup system. How good is your mothers hand strength?
Mountain bike shock absorbers are also used on scooters to provide suspension. Usually an electric scooter has the motor and batteries mounted in a rear sub frame that pivots at the floor pan level just behind the seat.
Safety.  What happens if the throttle sticks open? Also limit maximum speed to something reasonable. Take into consideration your mothers eyesight and reaction time. We had to limit the speed of some of the scooters we sold because we had 80yo men with poor eyesight terrorising the malls and retirement villages at ~10mph in a scooter that weighed in at over 250 kg (including passenger and basket full of shopping)
Mounting and dismounting. A seat that swivels 90+ degrees will be a very probably be a desirable thing for a woman that has had knee surgery and may still be using crutches, just make sure it latches in the forward facing position while she is driving.
Axle loading. Need to keep most of the weight on the drive wheels to maintain enough traction to be able to drive up small obstacles (kerbs, doorways etc). Keep enough weight on the front axle to be able to steer on smooth/slippery surfaces however. If you build a large outdoor only type scooter with large diameter tyres this wont be such a big issue.
I would suggest modifying an existing mobility scooter chassis if you can find one in an appropriate size/price. It will have steering linkages, tiltable steering column etc already setup and save a lot of fabrication/design time.
Square section steel tube is the most common construction material for the frames.
Hope thats of some help.
