Thread to Bolt
Thread to Bolt
Thread to Bolt
How exactly do I add a cosmetic thread to the body of a bolt?  I found a command in annotations but this seems targeted towards holes only, not bodies.
3D Innovations
Solidworks Office Pro 2007 SP2.2
Dell 390 NVIDIA FX4500
Quad Core Processor  4G Mem
RE: Thread to Bolt
Check the Help file for cosmetic threads > cosmetic threads. About 2/3 down the page is an explanation of how to add the cosmetic appearance to a cylinder.
Quote:
To insert cosmetic threads:
On a cylindrical feature (a boss, a cut, or a hole), select the circular edge where the thread begins. If the feature is a conical hole, select the major diameter. If the feature is a conical boss, select the minor diameter.
cheers
RE: Thread to Bolt
Yes, Cosmetic Threads are considered Annotations.  So you are in the right command.  As CorBlimeyLimey says in his response you need to select an edge.
Insert, Annotations, Cosmetic Thread
Read up on it in Help, you will want to scroll down the page a bit in Help to get the info you need. The top of the Help page does talk about cosmetic threads in the hole wizard. Scroll a bit further for your answer.
Anna Wood
SW 2007 SP4.0, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
