Polypropylene brittle temperture
Can some help me; I would like to know what temperature polypropylene becomes brittle at? I know that some polypropylene can be used for vials and go down to cryogenic temperatures of -190C.  Many Thanks.
RE: Polypropylene brittle temperture
Homopolymer around +5 Deg C
Copolymer around -5 Deg C
Impact modified grades down to around -40 Deg C and still retaining sensible impact figures (e.g Sabic PP6614 - Charpy Un-notched @ -40 Deg C is 40 KJ/m^2)There will be plenty of others from other manufacturers.
PP vials at -190 Deg C are no problem as long as you do not drop them - they will be glass-like. PP will not disintegrate just because of the low temp.
Cheers
Harry
What Pud said.
One thing you can do is to put the PP vial in a shroud of Basotect (www.basotect.com). Basotect is a melamine foam with the special property that it remains flexible and elastic even at liquid nitrogen temperatures and it's not too expensive.
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
