Who knows how to create ?
Who knows how to create own tool in ug nx2 manufacturing (for example rad mill, solt mill, dove tail ). I will be thankfull for instroctins?
RE: Who knows how to create ?
You can create a Dove Tail tool by entering a negative taper angle.  What do you mean by a “slot mill”?  The ability to create a User Defined tool is not available in NX2 it was not introduced until NX4.  You can create a model of a tool and display it operation and verify.  Check the help doc’s for the customizing UG libraries – Tool Assembly part Files.  To see an example retrieve the 2.0 dia indexable end mill UGTI0202_019 from the tool library and then verify the tool path – set the tool display to Assembly.
