wireless water pump controls?
Definitely the new guy here. Have a water reservoir with pumphouse close to 1/2 mile away, (pretty much line of sight). Right now has a 12 pair direct buried cable communication line for controls. Has been suggested to move to a wireless system, because buried cable has seen better days. How reliable are these systems. Are they user friendly etc. Cost is certainly a consideration, this is for a small municipality.
RE: wireless water pump controls?
Imm600;
I don't know what the 12 pair cable is used for, but if you can use one analog and two digital in one direction, say from the water reservoir to the pumphouse, Phoenix Controls makes a nice Spread Spectrum Transmitter/Receiver pair for $1000, very reliable if line-of-sight. If you need more, there are some very reliable units at about $2000 each end that can handle lots of information. All are 900 MHZ Spread Spectrum. I use Yagi antennas at each end, even if not required, in order to control emissions.
Steve Wagner
Agree with SteveWag, this is definitely a cell phone application. The only issue that you will have is cost. You have to have a pc, software, licenses, etc. However, the cost for the cell phone system is going to be much less than the cost for running a new data cable.
If youn have line-of-sight then the Phoenix device will operate up to 15 miles at a one time cast of $1500 to $2000. If line-of-sight is not an option, the cell route is the way to go, but monthly payments of around $50 and one time cost of $3000 will hurt.
I have used the Phoenix device maybe 5 times over about 6-years and have never had a failure. Ametek sells the same thing;
http://www.drexelbrook.com/products/product.cfm?ProductCategory_ID=85&Product_Id=336
 shows some selections.
This is the specific device;
http://new.ametek.com/content-manager/files/STD//2867102-DRX-LM1.pdf
Steve Wagner
