Model statistics-node count
Hi All,
How can I cound the total number of nodes/elements in my model before I run it? I have a meshed model which I would like to inquire "model statistics" on, but this option can be viewed only in the results pane. I dont have any results as I have not run the model yet...
RE: Model statistics-node count
Nodes and Elements don't exist until you have "checked" your model...until then, they are lines and points.  If you don't want to run the model completely, perform a check on the model.  This will validate the geometry, but not enter the stress calculation processing.  With a "checked" model, you will enter the results pane, but not have to wait nearly as long.
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
Thanks GBor, that helped...
