fraft direction
fraft direction
fraft direction
Hello again all.
I have a part and am trying to do a linear pattern.I get an error message " draft direction is not defined."
 It looks to me to be defined...
any advice?
Thaanks
Rip
SolidWorks 23007 Office Pro.SP 4.0
Compaq Presido 6000
Win XP
RE: fraft direction
I meant draft direction
Rip
Compaq Presido 6000
Win XP
RE: fraft direction
Ripper,
Are you trying to include a draft feature in your pattern?  I've found this to be flaky at best.  You may have to:
A) Perform the draft after your pattern.  This will obviously increase the number of selections needed for the draft faces, but sometimes this is your only option.
B) Specify a pull direction that is based on geometry not affected by the pattern.  Theoretically you're already doing this because you obviously can't specify a pull direction that doesn't exist before the pattern.  Tough to describe, but I've seen weird things happen with patterns involving draft features.
C) Specify different options for your pattern (pattern faces rather than features, geometry pattern, etc.)
D) Build the feature(s) to be patterned as a separate body, pattern the body, and then perform a combine operation.
All of this is pretty vague, but without having more information on what you're trying to accomplish it's the best I can do.
RE: fraft direction
Thanks to all!!
I figger the thing out....
Thanks!
Rip
Compaq Presido 6000
Win XP
RE: fraft direction
Great!  In the interest of helping people that encounter this problem in the future, what was the solution?
