Macro to insert all Assy's and Parts into a new assembly
Does anybody know of a macro that wil insert all Assy's and Parts that reside in a folder into a new assembly and position them side by side so they are not on top of each other?
I have something like this for AutoCad, In our company all geometry is blocked for each component or assembly detail. So we developed a lisp routine that will insert all blocks in the current drawing automatically and position them side by side in an array
Thanks, Tom
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Pro & PDMWorks 2007 SP3.0
RE: Macro to insert all Assy's and Parts into a new assembly
I don't see why you couldn't do this.  Are you asking for help about how to get started with such a macro?  I usually cringe to say this, but in your case, it might be a good way to start:  Use macro recorder.  Do the functions manually with macro recorder to see what is recorded for you.  Let's us know what happens. :)
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
Not a macro but a simple mwthod is to open or insert all the files en masse into a tempororay new assy and then use the explode function to separate them.
cheers
fcsuper
I recorded a simple macro and it works well for that job, but I need a macro that would be generic to any job.
Here is a rough specification
User would start a new assembly and set normal to the top plane
User would run the macro
Macro would utilize the current folder path
Macro would ignore all files except parts and assemblies. With an option to select one or the other or both
Macro would determine the x & y extents of each part or assembly to insert and then insert them all on the top plane side by side with a space between them. No mates are necessary
I was hoping somebody would have seen a generic macro like this somewhere
Tom Malinski
CBL, Exploded view falls short because not all components are in assemblies.
CBL, How do I insert all files "en masse" ? or is that just a simple way of saying insert them all one at a time graduate
Tom Malinski
Tom ...
By "en masse" I mean all at once. Just drag and drop a bunch of files from a Windows folder into an open assy. The components will be inserted with component origin to assy origin placement.
I tried the exploded view "trick" before responding here and it worked perfectly. Just window select all components and make sure the Select sub-assy's parts option is NOT selected.
cheers
Thanks CBL
you may have given me a simple work around without a macro. I wasn't even thinking about drag and drop.
A star for you...
Tom
Tom Malinski
