Block Labels in V19
Block Labels in V19
Block Labels in V19
It seems like the new Block Labels, in V19, work just like the old way of constructing AutoCAD attributes in previous versions.  In that, the order you create the Block Labels is the order they are in the list when you edit the Block properties after the block is created.  And they're worst, the point that you place the Block Label, you can't move that Block Label via that placment point (insertion point).
Does anyone know how to move the Block Label by grabbing that point?  And can I change the order the Block Labels are in when editing?
Thanks - Todd
