hard contact and mpc
hello
I'm modeling two solids: an hard contact exists between the two solids so that there is no penetration of one solid in the other. Then I want to constraint a part of the common surface with a MPC function in order to link the two solids.
An error message occurs : because of the MPC function and the hard contact, some nodes are over constrained.
What should I do in order to prevent the penetration and to link the two solids?
Thank you for your answer
bat585
bat585
RE: hard contact and mpc
Martin
Martin Stokes CEng MIMechE
The solid are in contact and during a weld pass I need to Tie the nodes ( time dependant function MPC) progressively.
Thank you for answering.
bat585
However, I'm not sure of how to (un)tie the nodes as a time dependent event (if you do, I'd love to hear it!).
