Sweep Boss
Sweep Boss
I have constructed a 3D wire frame that is the centerline of a Bent Wire that I want. How do I go about Sweeping a circular shape along this wire frame centerline?
The Sweep Boss/Base Icon is shaded, not lit.
I was able to do basically the same procedure on a wire frame that I constructed on one plane, but not when frame is in over one plane.
SW2006SP0
SW2006SP0
RE: Sweep Boss
That said, here's a couple of hints:
To make a solid sweep you need a sweep path and a section. You have the sweep path. Make sure the path you have is a single entity (make it a composite cuve if it's not). Then create a plane at the endpoint of the path and sketch the section. Use a peircepoint constriant in the section to constrian your section to the path.
-b
RE: Sweep Boss
Thanks again.
RE: Sweep Boss
B. Long
Dell Precision 380
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
AutoCAD 2005
RE: Sweep Boss
Stugots
Mechanical Designer
SW '06 SP5.1
RE: Sweep Boss
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
