corrosion by isobutane
where can i find corrosion rates isobutane Vs. carbon steel and isobutane Vs. austenitic stainless steel??
Temp : 100F
Press : 225 psia
Cormet
Temp : 100F
Press : 225 psia
Cormet
RE: corrosion by isobutane
regard
S.
http://www.corrosionist.com
Luis Marques
where can I find these corrosion rates publised??
I've already tried CORSUR (NACE) w/o luck!!!!!!
Cormet
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
In looking at 2 aerosol products with water as one of the main ingredients I see nothing that stands out as a corrosion inhibitor.
Water by itself can be very corrosive to steel even with inerting gases. I can't recall see water in steel containers without any corrosion.
All of my canned water, Budweiser, is in Aluminum cans.
With the recent losses of SS beer kegs to scrap metal thieves, the breweries might consider a return (for some) to aluminum kegs. These were spray coated inside with a food-grade wax. Empties were steam cleaned and re-coated.
kenvlach,
My cans are "real water" given out during hurricane Ivan by the Budweiser Co.
You should have seen the crowd form when a red Budweiser truck pulled into a distribution center.
You'll not find in CorSur or other DataBase isobutane+water. To know the corrosion rate of your fluid, is necessary to understand where this water come from, and the type of systems (is it a tank, a pipe, a can?).
Water, mainly, is corrosive if it contains dissolved O2 or H+, acids. If you have a closed systems, with water with a certain amount of O2 dissolved at pH near neutral, you will have corrosion until all the O2 is consumed by the corrosion process. Once the O2 is consumed you 'll not have any corrosion unless some O2 can enter the system and dissolve in water.
In my opinion if you want to assess the potential corrosivity of your system you have to define:
-type of item (tank,pipe...)?
-is it a closed system or open in contact with air? it will be stagnant water?
-what type of water you'll have; formation water, condensing from a gas...., and the chemistry (chloride?)
without all this information is not possible to say something.
regards
Strider
