Correct Material Properties to use for plastics.
I am adding Radel R to our material database in Inventor 11. I would like some input on which properties are entered into the material database interface in Inventor 11.
Referencing the Radel R link that I have provided (h ttp://www. solvayadva ncedpolyme rs.com/sta tic/wma/pd f/1/6/0/R5 _1_500.pdf) do I use the Flexural Modulus as the Young's Modulus? Do I use the Flexural Strength as the Yield Strength? Do I use the Tensile Strength as the Ultimate Tensile Strength.
I want to enter this data correctly in order to achieve an accurate FEA Analysis result.
Thanks in advance!
Tony
Thanks in advance!
Tony
