Lofted Bends (symetrical part)?
I am trying to create a symmetrical sheetmetal part using Lofted Bend in SW'06 SP5.1. I understand that when you select the sketches it depends where you select them to define the path from sketch to sketch. I would assume that I need to define more than one path. Problem is....It twists the side that is not defined. (I want my part symmetrical!) i.e. I have two sketches. One is a curled mustache shape with a flat bottom that curls up with radius' on each end. The other is (2) full radius' with the gap at the top.
RE: Lofted Bends (symetrical part)?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Stugots
Mechanical Designer
SW '06 SP5.1
Jeff Mirisola, CSWP
CAD Administrator
Here is the link to the part file.
ht
Stugots
Mechanical Designer
SW '06 SP5.1
Jeff Mirisola, CSWP
CAD Administrator
Kinda like how the lofted extrusion feature doesn't make straight lines from one sketch to the next..it seems to use a spline and curves the "straight edges".
Stugots
Mechanical Designer
SW '06 SP5.1
Jeff Mirisola, CSWP
CAD Administrator
just wondering.
B. Long
Dell Precision 380
P 4 2.80 GHz
2.5 Gig Ram
Solidworks Office 2007 Sp. 2.2
AutoCAD 2005
Coming from a Pro/E background, I guess its never been my practice to mirror within a "sketch". I didn't think of it at the time, but since have realized that SW treats mirred sketch entities differently. It recognized it as a single entity for some strange reason. Strange, but good to know.
Stugots
Mechanical Designer
SW '06 SP5.1
